General Front door hinge
Guy Incognito
My drivers door drops when I open it (and clips the top edge of the sliding door)and needs a good bang to shut it.
I see plenty of people have this. I can see where it's moving. The top hinge. I assume this isnt something that can be tightened and needs replacing?
My actual question is if a main dealer is the o ly place to get them? Can't even seem to find any on eBay which I thought was odd.
Any suggestions or should I just head to the dealers? Anyone know roughly what I should expect to pay?
I've seen the post about just changing the side that's connected to the door so that's my plan.
Has anyone else managed to fix this? I believe mine has had a new door in the past but looks like it has been fitted badly and has dropped too.
It also needs a new door check strap or roller or something because it creaks and doesn't work properly.
Also have a problem with the back door check strap which at some point in the past has escaped the mechanism and tried to make an escape through the door. Looks to be a common problem. It's also badly worn like the front
