Technical  front brakes
daveyb
Hi All
First post what i would like to know is what size allen key do you need to get the pads off
Thanks in advance
Davey
Hello there and welcome to the forum :D gosh it's getting busy on here now guys :p
I'm not sure of the size allen key, all my workshop manual says is remove the bolt (so possibly a socket rather than allen key) although this is something I'll be tackling next month (putting a set of highly controvercial (on here anyway) EBC GreenStuff uprated pads on :) so maybe you can help me!
I have the removal and re-fit procedure though if that helps :)
found out it's 7mm same as the fords! take the wheel off then 2 caps loosen bolts remove spring and pads then push pistons back, copper slip pads then refit easy ;) gotta do it tomorrow on mine and a mates mondy
davey
the joy's of taxing
