Hello all!
Here is a guide to fitting Punto GT management and Seb4 to your Uno Turbo.
Mine is a 1301cc engine, I brought the following bits:
Engine loom
Phase sensor
Crank plate
Pullys
Idle control valve
TPS
ATS
Injectors
Bassicly all sesnors/Parts from a Punto GT…
Firstly injectors.
This is how to fit PGT injectors to your Uno.
To start
So compare…
Take of bottom parts
Trim pinttle cap
Next trim the plastic around the top and remove the o ring
All trimmed and ready, the hose is hard to push over the barbs but it will never come losse!!
New seals
Ready to go
Fitted
So… here is the before..
Taking out loom
New Garrett GT25 with inline filter(Thanks Birdracer)
Turbo on
Turbo outlet
Next up is to change the pullys to the thin tooth type on the GT (Less chance of belt slipping)
Old
New
New belt fitted.
New bits to go on
Bottom pully on
Coil pack on
PGT loom
Fitted a few bits
Phase sensor
Knock
ATS
TPS and adapter plate for RS Turbo
Fuse and relay holder
Still a fair bit left to do but I can confirm it runs like a dream!
Engine loom
Phase sensor
Crank plate
Pullys
Idle control valve
TPS
ATS
Injectors
Firstly injectors.
To start
So compare…
Trim pinttle cap
New seals
Ready to go
Fitted
Taking out loom
Turbo on
Turbo outlet
Old
New
New belt fitted.
New bits to go on
Bottom pully on
Coil pack on
PGT loom
Fitted a few bits
Phase sensor
Knock
ATS
