Tuning Fitted a tuning box to my 150 multijet!
cpc
Just thought id post my thoughts on this little gadget that im very impressed with now ive done a good few hundred miles with it.
The box in question is a Synergy 2b tuning box that also adjusts the boost pressure via the map sensor. I also bought a optional dash switch so i can adjust it from the cabin this gives me a eco mode, total off and what ever setting is on the box.
I cant believe now smooth it is and guess not appear to produce any smoke even on the high settings.
Its not all good news because im getting some clutch slip on the higher settings, so have it on a more sedate setting with lower torque below 2500 and high power above
So far fuel comsuption appears above the same ( not going by the OBC reading), i also fitted a egr blanking gasket at the same time.
I have no idea about power but am told its around 190bhp+:devil:
Chris.
Result. Glad you like it with the box on. Makes a big difference. A remap would give a more progressive increase in power starting at lower revs rather than a massive gob of torque at 1800 rpm.
Ive got it set so its only slighlty more powerfull below 2500 rpm but very strong from that point to the red line.
I think this is done mainly by boost pressure rather than fueling on the setting im using.
