Tuning Fiat Tipo Sedicivalvole Balance Belt Removal
mustaya
Dear Friends
I have a question. I want to make a small-scale modification. Can I cancel balance belt? Does it make a problem? Does it produce vibration problem will occur?
I'd appreciate if you help in this regard.
Regards
Mustafa
you can easily remove the belt and let the shafts rotating freely (like Lancia factory did it for delta gp. A..) ..I did it on my Tipo 8V (on 16V build I removed them and blocked oil channels..)
you will probably notice no vibrations and get higher reliability, because of there is suddenly nothing (balanceshaft belt) which could get in to the timing belt ...
