B bladeoner New member Joined Feb 3, 2005 Messages 2 Points 2 Feb 3, 2005 #1 Where can i find the Fusebox? My headlights ain't working i'm searching for the fusebox so i can change the fuse and maybe fix the problem.
fixit New member Joined Jan 1, 2005 Messages 66 Points 14 Feb 3, 2005 #2 around knee level to the side of the steering column... a handle marked FUSE. pull it and you can then lower the fuse box.
D danny_bellis New member Joined Oct 30, 2003 Messages 17 Points 3 Location Liverpool, United Kingdom. Feb 8, 2005 #3 bladeoner said: Where can i find the Fusebox? My headlights ain't working i'm searching for the fusebox so i can change the fuse and maybe fix the problem. Click to expand... If the fuses are okay check the wiring on the back of the bulb, it's prone to melting at the connector so you may have to splice in a new connector.
