S SHEFFWED New member Joined May 16, 2005 Messages 17 Points 11 May 16, 2005 #1 CAN SOME1 HELP, CAN'T GET INTO GEAR WHEN ENGINE RUNNING,NO PRESSURE ON CLUTCH PEDAL,TRIED BLEEDING CLUTCH SLAVE VALVE,STILL THE SAME WHAT DO I NEED TO DO NOW. :bang: :bang:
Trancendental Patron member Parked in the garage Joined Mar 29, 2005 Messages 5,034 Points 806 Location NW London May 16, 2005 #2 Might have to replace the Master and/or Slave Cylinders. Also check the pipes that hold the fluids. one of them may have burst.
OP OP S SHEFFWED New member Joined May 16, 2005 Messages 17 Points 11 May 16, 2005 #3 How Do I Replace The Clutch Slave Cylinder On A Fiat Tempera ,is It The One Underneath The Battery Tray
Trancendental Patron member Parked in the garage Joined Mar 29, 2005 Messages 5,034 Points 806 Location NW London May 16, 2005 #4 If its the same as a Tipo then yes. I think there is some infor on it here. https://www.fiatforum.com/showthread.php?t=25411&highlight=Slave+Cylinder
