Technical  Fiat punto spark plug
Mshiha
Egypt
hello , my car is FIAT Punto II Hatchback (188) 1.2 60 (188.030, .050, .130, .150, .230, .250), Year of Construction 09.1999 - 12.2010, 1242 , 60 PS
im looking for spark plug and i found
BOSCH Iridium Spark Plug 0242140514 [ YR6KI332S ]
and
Bosch - Spark Plugs Nickel - 0242135515 ( YR7DC+)
can u plz tell are the compatible with the car or which one matching better
the cataloge recommended ngk dcpr7e-n-10 or bosch yr7deu but they are not available any more
My local nationwide car shop has DCPR7EN-10 and DCPR7E plugs
The 10 is the gap size which you can change yourself. The N is the 'construction type at the firing end'.
The outer shape and the thread size and the reach of the plug and the temperature are handled by the DCPR7E letters.
Thank you for your answer but both ngk dcpr7e-n-10 or bosch yr7deu are not available in my country
I found that two YR7DC+ and YR6KI332S
And the last one that I wish to match with my car because it's double iridium but I still don't know will it work fine or no
