Technical Fiat punto mk2 throttle fault
pudpie
Engine will start and tick over but when revs. applied the engine cuts out, like the car is stalling.
Have had the following work done:
Fuel pump & pressure
Second hand throttle body
4 x injectors
Fuel drained
Code read
All injector sensors replace
checked plugs
fuel pump relay
No codes in memory
Struggles to start cod
when hot tricks over ok
struggles to rev with throttle pressed fast.
and still the problem not sorted does anyone have any ideas please. If next suggestion is the Engine Management System to be replaced does this have to be programmed to the car?
