good day my fiat palio go 2005 model 1.2l is giving me lots of problems its heavy on fuel i changed the map sensor snd the tps and the spark plugs and the fuel filter and replaced the rings and replaced the fuel injectors it just not want to stop misting and now the starter is broken to im raly fed up i dont know what to do anymore
Tracy , Is there a reason for you not to approach FASS (Fiat Authorized service station) ?
here in INDIA we donot approach FASS cause they tend to charge a lot for simple tasks ,
what I have done is purchased a 3 pin to 16 ping cable ,
2) a Bluetooth ELM 327 scanner
3) installed
MES (multi ecu scan) software and hooked up my palio
MES software is just amazing , I am planning to buy the license soon ,
rest you can run a scan against your cars ECU and get the exact problems reported ,
lemme know if this helped ,
you can buy 3-pin cable off
ebay.com or your local ebay site ,
also you can buy a Bluetooth ELM scanner from ebay ,
MES is here
http://www.multiecuscan.net/
