Technical Fiat Ducato motorhome ECM code PO481
Floggs100
Help please - I have a Fiat Ducato based Motorhome (2008) that has come up with an ECM error code PO481 - Engine Coolant blower motor 2 - wiring engine coolant blower motor problem - does any one have ideas what this all means - do i need to get it in to see an Auto Electrician or a Garage mechanic - i have taken to three general garages all who dont want to know because they say that the wiring in modern vehicles is to complicated for them - do I just take to a Fiat specialist - does anyone have any idea what sort of cost might be involved ie: anyone had a similar problem - any ideas please - regards
Hi
This could be possible under bonnet fuse box problem or the relay on the fans if it has air con fitted. To check this out you will need a wiring diagram.
Many thanks - I have phoned Fiat Assist and logged a case to see if they have any ideas as not sure where to get help - thanks anyway
