Therumrunners
This is not the usual airbag problem but I hope somebody might be able to help. The story- airbag light came up and scaned as low voltage, fault wouldn’t clear B0100-49. New battery fitted as precaution and airbag module sent to Northern Auto Tech. Returned with a note saying that proxi alignment would be necessary. Reinstalled airbag module and connected MES. Odometer was flashing and the airbag light was up and now also the seatbelt light. Unable to connect to airbag module but everything else was ok. Connected to the Body Control module to do the proxi alignment and saved the current proxi file onto the laptop. Noted the airbag module was showing in red as ‘removed’. Completed the proxi alignment ok. However, this is where the trouble starts. There is no airbag light coming on at all on turning the ignition key and the Body module doesn’t show the airbag module. It’s like the airbag module doesn’t exist. Removed the the module and the odometer is steady and not flashing. The van is now happy without the airbag module but I am not! I copied the current proxi file and printed the before and after files to compare. They are both the same. I am now at a loss. Any help much appreciated.
I have a reply on the MES forum as follows. He did wonder why I did what I did and I agree totally, I should have got more info before proceeding, my lack of experience with the software.
He did say that the airbag module should go back for checking/further repair, which it has. He also said that if a good airbag module was fitted the BCM would pick it up and approximate alignment would fix. This fills me with optimism. Is there anybody out there that would agree with this.
