Technical Fiat Ducato 2.8 1999 oil service
RedLabel
Hello, i have an old 1999 Fiat Ducato 2.8 engine (8140.43) and i want to change oil + filter.
Please tell me what quantity of oil do i need and what type. 15w40 is ok?
Thanks.
Thanks.
About 6 liters of oil, 10w40 is better for Romanian in winter, 15w40 is too viscous under 5 Celcius.
About 6 litres of oil if you've changed the filer too. Ordinary mineral oil or semi-synthetic if you're feeling rich.
Even if it gets very cold where you are in winters, don't go any thinner than 10W40 engine oil....if you do, then the crankshaft oil seals will start to weep as they can't cope with modern very thin oils.
Remember also that the 'MAX' mark on your dipstick is exactly that: it's the Maximum amount you can fill the level to. Try to fill it to a little below that mark, as overfilling can have serious consequences.
