Technical Fiat croma 1.9 JTD 88 KW strange squeaking when the engine is cold
Milos196
Hey, I want to advise that you have someone similar experience.
When driving a car after he stood all night until the engine heat up to operating temperature, skipan hear strange, as if something gill lid. It's only when I start to hear your foot off the gas pedal and the car engine dobrzďuje ...
Sound as if it comes from the hood, or from the wheel.
Once the engine warms up to operating temperature classical, so that the two, or other stages of the squeak. This is a problem only when the engine is cold. 88kW 1.9 JTD
squeaking stops when the engine is at operating temperature, then I need to travel 1000 km and the squeaking you hear.
I would appreciate if someone can know whether a similar experience.
Is it the alternator belt? It's just to the left of the engine as you look from the front.
If so then it needs a new belt and/or a tensioner. Or it could be the the alternator or something else is getting too stiff. It needs a good looking at to find the cause.
I agree with Doofer, you should check the alternator drive belt first. Especially in the cold weather the load on the alternator is heavier so a worn belt is more likely to slip on the pulleys until the battery has been recharged.
Hi, alternator belt and no it's not. I replaced the belt and it is not no pulley, kontolováno. Liven it (scrape like something spawned) somewhere on the left side of the engine compartment and it starts to squeak when the engine begins to warm up and ends when the engine is at operating temperature. Now in cold weather it creaks a long time. Brakes, suspension checked. Consult please.
Is the English by google? It was the "something spawned" that got me.
Your English is better than my Czech though!
Check your battery voltage while it's making the noise. If it's dropping while it's noisy then look at the alternator pulley.
