Marty Fiat
I have a 2018 Fiat Ducato Motorhome in the Uk. The confortmatic gearbox is playing up and I can't drive it at the moment. The problem is that when I start it and I put in 1st or reverse it stalls straight away and after a few attempts it says the gear no gears can be selected and consult the user manual. I have it booked in for repair but they are assuming I need a new clutch. The problem is I think the clutch is not engaging and so the motor stalls as you have to have your foot on the brake to change into 1st gear from neutral. When it first started happening I was able to get it going forward by being quick getting off the brake and onto the accelerator. Once going it changed gears no problem and drove normally. Once I stopped it stalled again. So I think the clutch is ok. It's not engaging initially. Has anyone else had this same problem and found a fix for it other than pulling the motor out and changing the clutch?
