fao "tidyjug"
fao "tidyjug"
M
mechanic (davo)
tidyjug im not trying to be funny but you say the faults fixed but the lights still on theres no difference in drivability from before you changed coilpack, obviously faults not fixed,so why would the light go out?? if ya wanna fix it look at it logically ignore the system, check the basics enough fuel?(blocked ,partially blocked filter)timing belt(marks aligned)plugs in good cond if shesshowing a fault check above first email if youve no joy ill try help ya out if i can
the 1.6 has a fuel filter in the petrol tank. my tank has been chnaged with a new one, including pump and sender unit, there has also been a recon head fitted and a new timing belt. none of this has affected the fault in any way. only 1 injector has been changed but this made no difference either. the previous owner spent 1000 tryin to sort this out then sold it to me for 365 so i'm stuck with a broke car. dont know what else to try...
How about knackerd injector?? had to change mine on the 1.6 last year seems a common problen on them.....
justin
S
5
809
sly si
S
A
2
763
M
A
1
324
M
S
2
452
sly si
S
K
1
603
M
