Alright chap, I couldnt get the pic to properly upload due to my ahem downloading session using up all my connection last night but here is most of it.
thats the remote central locking relay that comes in the kit that you buy which should be plug and play.
I plugged it in many moons ago to find that the central locking still works but the remote central locking does not
the batterys in the fobs are fine too.
any ideas what could be wrong with it? Tom?
I know its a long shot but I took it to fiat and they said dunno whats wrong with it buy a new one...very helpful...NOT
After seeing the pic, I have to get mine out to see where/what the problem could be
Will contact you as soon as posible. In the mean time Tom will deffo give an ansver
thing is, nothing looks like theres anything wrong. no burnt or broken traces etc.
a lot of the unit is sealed under the metal casing.
am I right in thinking that one of the spades takes a 12v constant feed + one a negative and then a signal from one of the blips causes the power to drop off and activate the central locking seeing as its a negative switching system?
I'm a newbie with this sort of thing so appologies for sounding stupid if I have.
Did you get a plastic blue card whit the unit ?
If yes, the sure testing can be done at a Meta System alarms supplier.
They can quick check the unit according to the card. - here its free of charge
As I know yes, but aint sure. The thing is, you sead that only the remote locking aint working, the key lockind does, so I realy think you got faulty fobs, rather then the relay. If the card maches the relay they can reprograme the fobs.
