FAO - Nigel
FAO - Nigel
B
Briggsy
Hi m8,
Do you have a fitting amp guide and removel of standard head unit for the bravo on you new site?
IF NOT
Can someone help me I would like to know how to remove the standard head unit and where you can feed the +wire from the battery through to the boot.
PICS WOULD BE A BIG HELP IF YOU CAN?
Briggsy
answer
sorry for hijacking nigels post but i have the answer to routing cables. i found it the hard way.
remove the battery and tray and you will see the bulkhead. now in the passenger footwell remove the various bits of trim around the carpet and pull the carpet up a bit. there is a rubber grommet and cables going through the bulkhead behind the glovebox (which is easy to remove). pull the grommet out and make a hole in it for your cable and a hole in the soundproofing on the other side of the hole (take care not to cut wires). you now have the cable through the bulkhead. route it along to where you want it and try to get the carpet etc back the way you found it!
regarding the head unit - the easiest way is to go to a fiat dealer and get them to pull it out but if you dont want to do that then you can do what i did but that will leave the head unit in about 30,000 pieces (use hammer and big scrwedriver). if you want i have a spare headunit so if you bugger it up you can get one back again!
riclemus
Re: answer
THANKS FOR THE HELP M8.
WILL BE FITTING IT SOON BUT WILL HAVE TO DO WITHOUT THE CD CHANGER UNTIL I GET A HEAD UNIT THAT THAS THE RIGHT FUNCTIONS ON.
BRIGGSY
radio removal
Im no radio thief but i manged to get the old head unit out in about 30 seconds there are only 4 clips!!
Hijack
No probs please do!
Easiest way to get the head unit out is using feeler guages. Open tape cover, slip feeler gauge down L/H side and pull. Out in seconds. Mind you...you have to find your feeler guages first though!
N
Alex
How?
Will be fitting my AMP and 6x9's at the weekend.
Briggsy (Thanks for your help)
Re: Re: Alex
How did you get out the head unit in 30sec?
Briggsy
Re: Re: Re: Alex
By....do!
Try it!
Nige
Photos
I am working from home tomorrow and will take some pics of how to do it for the site if it helps.
Nige
Re: Photos
Hi Briggs,
Nige is right mate with the clamps its out in seconds.
I went to fiat and was cheeky and they did for free...
Al
S
5
813
sly si
S
A
2
763
M
A
1
324
M
S
2
452
sly si
S
K
1
603
M
