FAO: Joske
FAO: Joske
K
Kris
Hi mate,
when you fitted your mistjets on your car how did u make it so they covered the whole windscreen? ive fitten myn but they only hit the bottom of the windscreen?
Kris
I just fitted them and that was it, they hit 3/4 of the way up the screen. I would check they sit flush to the bonnet, check your non return valve is ok, check for kinks in the pipes and check to see if the motor is ok.
Failing that you could fit washerjets from the new bravo, they are also mist and fit perfectly.
Fiat Marea Chrome Front Grille. Fiat Bravo MK2 Front Grille.
ePER V4.0 2008 DVD, Bravo & Marea Workshop Manuals, Fiat Bravo Haynes Manual &, Fiat Bravo Owners Manual on CD etc...
S
5
771
sly si
S
A
2
741
M
A
1
312
M
S
2
446
sly si
S
K
1
586
M
