FAO: Ben B/boot light always on
C
Chris
Hi Ben/all
Chris here...
Just noticed that the boot light is on constantly and I'm a little worried that it'll kill the battery. Just wondering if it's wired up that way for the neons or something as I noticed that a wire another wire is linked up to it, and if it'll infact kill the battery.
I press the button by the connectors but nothing.
Any help would be much appreciated.
Chris
Having the boot light constantly on will eventually drain the battery...
Leave the wires connected, but take the bulb out and the problem should be sorted..
Just make sure everything else still works afterwards though..
I don't think there's an aftermarket alarm. I'd rather try and sort it and keep the bulb in to be honest.
Chris
By ?I press the button by the connectors but nothing.? you mean the small metal pin that is on the down part of the boot ?
If so, take that whole line out and check the connectors under it.
Members Site - - - - - - - My Site
Yeah, at the bottom there are 4 (I think) connectors with a button that presses down to turn the light off I believe. Pressing that doesn't do anything.
I'll have a look at it tonight, providing the weather is ok.
Chris
As I remember left of the far left one should be a small metal pin sticking out. When pressed in it should turn off the boot light. Normaly it is pressed by a plastic square shaped bit that is on the boot lid. Now if you press the pin with hand and the light goes out, the plasic on the boot lid isnt pressing the pin like it should - lover the boot lid by winding in the rubbers on the boot lid sides. If it dosent go out when you press it by hand - the switch is malfunctioning - you will have to take it out
I have not closed my boot properly on 2 occasions and both times it flattened my battery overnight. Cause maybe a constant earth
two fix options
first the proper one is to replace the switch by going to a scrappy and getting one out another car
or second which is more simple! remove the bulb ;)
@ Sven where is this switch for the boot light on/off cant find it on my mk2, have tested wiring and fuses and other than switch all is well but not functioning. And would like to get it fixed asap/
Drives: Bravo HGT 155 Nov 2000 - Vroom Yellow (y) :D
Family: Punto JTD ELX 2001 - Met Red - Volvo S40 2.0 TS 2002 - Red
Old: Brava 80sx 1999 - Red - Punto 60sx 1997 - Red
Mine is a Mk2 and i cant find a switch. I thinkit must be in the wiring somewhere. I'll have a look in haynes
Yea can find it on the wiring diag but not on the car.
boot light on Fiat Brava
I have the same problem with a Brava I have just bought. though the light just needed replacing but once fitted it wont go out and its red hot if its left in.
Not sure what to do. Have read the forum but am none the wiser
F
7K
F1-ANG
F
E
1K
E
J
1
775
Dark Lurker
