General  Fan dead
General  Fan dead
Sorter
Ulysse P-reg (96) NOT Air-Con
The heating/cooling ventilation fan has packed up
Is there a fuse (hopefully) - if so where can I find it
If the fan needs replacing, where is it fitted
Thanks for your help
are you sure its packed up and not the slider switch playing up? I had a problem with mine where it would not work and i slightly lifted the slider switch to turn the heater on as I slid it and it all worked again, it was as if the slider switch was not moving the internal parts properly, try it you have nothing to lose, dont force it just gently lift as you slide the leaver
It's fuse #17 -15amp behind the drop down glove box.
