I have a 2.8td fiat engine (Year 2000) in my Hymer Ducato motorhome.
The fan heater keeps melting the fuse when on full for a length of time.
The switch seems to work fine in all positions, the regulator seems to work fine as it draws 4 8 12 16 amps in positions 1-4. I figured maybe a bad connection on the fuse box so bypassed this but still kept a 30 amp fuse in line. No difference so I took the fan motor out and had it checked at my local motor rewinding company, they said that the motor is fine.
So now I am out of ideas, on full power the amp readings just climb slowly until the fuse burns, it doesn't blow as such just melts.
Any help could save my sanity.
I have a motor on it with a part number 591920600 I believe that this may be for a non air conditioned vehicle, mine does have air con.
Fiat gave me the part number as 71734232 and said this is a new number, it used to be 46722702 neither of which match what I have.
Could this be the problem? what would the difference be between the motors? does the aircon draw more amps. I have only recently bought the vehicle so am not sure that this hasn't been a problem since this motor was fitted. A new motor is £191 so don't want to buy unless I am sure that the motor is the problem.:bang:
