Technical  Exhaust
Technical  Exhaust
shaun
Established member
United Kingdom.
hi wondering if i can replace the original exhaust with something a bit more sporty sounding.I know i will have to mod something, but i dont know what exhaust to use, any ideals will help
Thanks Shaun
The easiest option to obtain is the CSC exhaust which replaces the entire exhaust system. It isn't to everyones taste and the matt black finish on the silencer tends to burn off after a while (it goes white).
The ultimate option is the original Abarth system but these are exceptionally rare and certainly impossible to find new.
Avoid the ANSA systems like the plague! Not that I think you can find them anymore but I've seen a few secondhand systems around over the years.
Thanks jimbro, have you ever fitted a backbox off another car i have heard somebody fitting a honda one
PBS "style" headers are pretty common, and there arew a few "short"headers out there that are aimed for better top end power. Monza, CSC, ANSA, Abarth, and a few others all made exhaust systems for the X1/9, but some are quite rare, so check old "junker X's", because you never know what you will find. (lastly) if emissions arnt of your concern, id suggest buying a long/or short header, and run a strait pipe to a Magna Flow muffler. this system should be under $300USD
The last system I tried was the CSC one and while it was an improvement it was also a deep disappointment.
Since then I've been running a turbo lump with a very simple exhaust system attached...
what about duel exhaust, I've seen those before. Anyone know how I could get my hands on one?
EDIT: Oh the monza is the one I saw. anyhow, I stand by my question.
id check evil bay, ive seen dual pipes there. or i guess you could try a coustom setup? i made a pic of what i think would work okay, if emissions arnt of concern for your area. though im sure a cat could be added w/ a few mods.
this pic was originally to act as a "tip" for another coustom pipe for a friends X1/9, but after looking at it, a cat could be substituted in the mufflers place, and used to conect the "down pipe" to the new piece
