Technical  exhaust`
Technical  exhaust`
London
Hello there mates!!!
would anybody know if a uno turbo back box will be a strait replacement to a fiat uno 999cc?
and also i really want a suspension kit where is the cheapest place to get it?
bulldog5046 said:
wont cause the engine to backfire will it? bit worried as i heard it can damage the catalic convertor
Nope, just using the backbox wont do you any problems at all. you wont get a power increase, just a better exhaust note.
If you was to use the wider bore exhaust sections from the UT where possible, you'll loose backpressure, which will cause you alsorts of problems :)
Hei.
I´ve learnt from exhaust experts that the FIRE engines don´t need back pressure, so there is no problem with changing the whole exhaust to whatever you want. The pipe on the 1108 cc is 1,5" so a pipe expander will be used to compensate for the turbo backbox size. Also on the 1108 cc there are two backboxes so when the rearmost fell off due to corrotion, I simply replaced it with expanders and extenders and a nice chrome tail. :)
See https://www.fiatforum.com/showthread.php?t=32083
Morten.
As for suspension, if you want 35mm lowering get apex, if you want 60mm get Gmax.
All other kits make the front look higher.
