Technical  exhaust manifold
trissy
hi. on inpection my exhaust manifold has some small cracks and there is signs of leakage.
Can these cracks in cast metal be welded? Or should I not bother. I have a MIG.
tris.
You really aren't having much luck with that car!
Cracked manifolds are pretty rare on an X1/9 thanks to the way they are mounted, the normal problem is the studs get bent where the exhaust mounts.
Don't weld them up unless you absolutely have to - it simply isn't worth it
Got bits if you need them (still)
I'm going to be chopping my donor car up with a grinder in the near future - if there is anything you want me to rescue from it can you let me know and I will put it aside otherwise it will be going in the skip
