Technical Exhaust manifold
tattyoldvan
dorset
What exhaust manifold fits the 1.0l, i have picked up two used ones and both are cracked as bad as one fitted, will 1.2 punto 8v ones fit, failing that i suppose i could get exhaust gasket and get one made from lump of stainless, rather not though
Classic 999cc Panda manifolds also fit, as do 1108cc FIRE manifolds (Cinq Sportings, Seicentos and Punto 55's). You may need to check downpipe compatibility depending on which model Uno you have.
I have a good exhaust manifold of my 999cc (FIRE) Uno I'm breaking :cry:
Just removed it last night
the Uno is the 1.0 IE (with Cat) version but I should think the manifold would be the same for the non cat earlier Unos. (y)
Edit.. I've just checked it and can see no cracks.
I've replaced 2 studs that snapped when splitting from the down pipe, so all 3 are now good.
Brings back memories Ah Chas ;)
Yeah, Louie, sorta yer perm box out.
I tried earlier too, but "full o' mails, nay room f'more" was the error I got back.
Fan mail for me?
I never got any.
Did you send it to the correct ucof?
:p
I did.
I basically just said "thanks, parcel received, blah blah blah, yakkity schmakkity"
Sent it again after you said you had cleared some space out.
