Technical Error code
ema
Help needed I have 500x sport 1ltr on it started misfiring and limp mode and saying check engine I've had some one plug it in for me and it has come up with code B3010 any advise on what it is please
hi ema.ive just signed up to fiat forum. your post on the fiat leak into boot is exactly the same problem i have. did you manage to fix it? and how? sorry to be on wrong thread. newbie.
Hi i did it was the right hand joint in the recess of the boot pillar, so we took the inner panel out in the boot then when the boot is open if you look near the top of the pillar where the roof meets the seam of the boot recess then get a watering can and run water on seam quiet fast and on mine the water ran down the inside of the pillar into the boot so could be same as problem your having I just sealed the seam hope that helps
