as im toying with the idea of a d16z6 honda vtec powered one
People usually put in some of the other fiat engines in the front (check out the FAQs in your signature).
is it cause its just not physicaly possible to fit anything in the front ?
Or is it that its not sensible? Small cars only need small engines to out perform large cars with large engines
As they say, anythings possible. But to fit an engine in the front of a cinq thats not from the same 'family' of engines then you will be looking at quite a bit of fabrication work and may involve re-making the front of the car. If you are up for that, then go for it. But if I had a 300bhp civic already then I wouldn't even want to touch my cinq, and I love my car.
ye ive looeked at that but from the faq's and other searching ive done there seems t be a big jump from the 1.4 16v to something mid/rear engined and rwd but cant find anything inbetween, is it cause its just not physicaly possible to fit anything in the front ?
if its a b16b he should have bo trouble shifting it and they are worth a bit tooThe honda block will make it so heavy at the front it will just understeer everywhere. But i do love the idea of a 300bhp cinq, so if you want a B16B turbo'd civic engine from an EF civic running around 310 bhp then my mates got one in his drive he wants rid off (p.s. it comes with a free EF civic)
cheers
jamie
cheers
jamie
. But i do love the idea of a 300bhp cinq.
How many times do I have to say this? :bang:once you pass the 150 HP mark in the cento (if you manage to pass it), adding more HP won't matter much because you'll be spinning the wheels in almost every gear
It's only ~750 kg and no electronic skid/slip/launch control, so having 200 or 300 hp in a cento won't make much difference probably, not in the practical sense.
Edit: and 150 hp is quite doable with a turbo.
Sorry, that's what i meant, but power doesn't come without torque, and if the engine has 300 bhp, then i wouldn't expect it to be torqueless, hence it would be undrivable.How many times do I have to say this? :bang:
Ultimate power isn't the problem, excessive torque levels are. So produce 130lbft at 8000 rpm & you've got controllable access to 200bhp, produce 260lbft at 4000rpm & the only place you'll be going quickly is a ditch.
1.4 16v plus box is around the 150kg marker with fluids.
But it's up to the engine developer/tuner where they put that torque! Now it's more than possible to make an engine which produces peek torque in the mid to late 6s, possibly early 7s & peek power is in the late 7s/early 8s while making around 80% of that down at 3k. What you find is that though the car won't feel as quick as something that the sames torque down in the 3k area it will actually be quicker A to B when you push on because the thrust delivery (what it's really all about) is more progressive & in line with your real needs.Sorry, that's what i meant, but power doesn't come without torque, and if the engine has 300 bhp, then i wouldn't expect it to be torqueless, hence it would be undrivable.
