ex19
Hi all,
Very new to this, but thought I would say hello to you all as a new member and see if there is anyone out there that could possible help me find the solution to my F-reg (1989 X1/9 VS), cutting out/stalling after running fine for miles in some cases.
It will always seem to start and run perfectly for a while but then stall again and again (Only when driving.. never on idle at lights etc) which is more than a little strange. The precursor to it cutting out (even if cruising at 60mph happily) is the rev couter flicking up and down and some occasional engine stutters, though sometimes it skips that stage and goes on to just stalling the engine.
The car has had new fuel pipes fitted last month, 2 inline filters and a new fuel pump in August last year, though the fuel is not seeming to get into the filters at much pressure..
I also wondered if it was an autochoke issue maybe? When started from cold it seems to rev steadily at 4000rpm and not come down on its own until the accelerator is tapped which seems odd, though could be entirely normal.. I am certainly no Fiat mechanic thats for sure! The pipes to the housing do not seem blocked as I can blow through them. I did find that cleaning the connectors to the temp sensor on this housing improved the issue a little but certainly did not cure it. I can now usually drive about 5 miles without too many issues now! Water temp on the dash is always a little below 90 and I think the fuel pressure guage is not working as it certainly has oil but the needle always sits at the bottom of the guage.
Not sure what else to tell you really,
Hmmm...
If there is anyone with even a bit of guess at what it could be and where I can start looking I would be extremely grateful.
Thanks again for your time if you got through to this stage, and hope to hear from you soon so I can actually get out and have some fun in the thing!
Regards to all X1/9 owners out there,
Nick
Hmmm...
Nick
