percy punto
- Joined
- Oct 6, 2012
- Messages
- 8
- Points
- 2
i have a punto 1.2 8v 2002 with about 90k on the clock. the car runs fine when weather is dry but when we have had a lot of rain like last night i get the management light come on and a code that is cylinder 4 misfire.
i have changed the plugs, ht leads,crank shaft sensor .have had an emissions test and that come up normal also had a live reading data check on a snap on modus and that doesn't show any problems either.
anybody got any ideas as i'm fast loosing patience with the car.As the fault is only when wet i'm a bit confused to say the least!
Thank you!
Thank you!
