I have a tipo that is draining the battery overnite. I have replaced the battery but sill the problem continues. Two days ago I was looking for problems and on replacing the earth terminal on the battery heard a clicking on checking found the drivers door locking button was making the noise by going up and down. (The car is not central locking) I removed the fuse to the courtest lights which stopped that problem. My battery is still draining over nite. When I check the battery using my volt meter (neg/ earth lead removed from the battery the other end of the volt meter to the neg post on the battery I have a 12v drain when I remove the fuse that powers the horn, cig lighter and the brake lamps the voltmeter drops back to .6 drain. this fuse also powers the radio I have the same effect when I remove the radio fuse.
Last night over two hours I checked the voltage of the battery the readings were 12.69, 12.67, 12.66, (at this reading I removed the cig fuse) 12.66, this morning before I started it it read 12.58. The alternator is putting out 14.+ volts.
Anyone have any ideas what to do next.
