dukeofdream
- Joined
- Jun 16, 2019
- Messages
- 2
- Points
- 1
Hi all. I have a very weird issue... Engine will suddenly die, radiator fan kicks in even when the car is cold and i'll get a bunch of DTCs...
P0201 - injector 1 open circuit
P0202 - injector 2 open circuit
P0203 - injector 3 open circuit
P0204 - injector 4 open circuit
P0033 - BlowOffValve - open circuit
P0433 - EVAP valve - open circuit
P0135 - Lambda sensor 1 - open circuit
P0141 - Lambda sensor 2 - open circuit
P0243 - WasteGate valve - open circuit
Problem started around 3 months ago and left me on the street... I brought the car to a shop that couldn't figure it out and after a week i went to get the car as is. I studied the eLearn trying to find something in the very poor electrical diagram. I was searching for a junction D004(1c on the picture) and lightly pulled on a bunch of wiring. Didn't find the junction but tried to start the car anyways. It fired right up, all the DTCs gone. Fast forward 3 months to today. I swapped the cams for the 150hp ones and changed the valve oil seals. After everything was put back together the car started and 30 seconds later it died giving me the exact same DTCs. I restarted it and it worked for a few minutes and then again the same... i moved a bunch of wiring again, checked all my fuses and relays. Car started drove for 500 meters and died again... Has anyone seen this before? Funnily enough all these sensors that suddenly went missing, have their pins one right next to the other on the ECU side (Picture 2)... ECU was checked and is fine. My guess is that it's a single wire that either provides 12v to all these sensors or its a common ground that only affects these... I really can't figure out from the diagram if the sensors have a constant 12v and the ECU is regulating the ground or the other way around. A common ground would make much more sense but i just can't find anything loose... Any help greatly appreciated
- Model
- Bravo T-jet 120
- Year
- 2008
- Mileage
- 180000
