Hello again all Fiat 'lovers'
Can anyone help with this problem please.....
P reg 1.9tds. Running along at no particular speed when ....the engine jolts and sometimes dies. It is not a gradual die off as though out of fuel, it is instant (engine and dash as if switched off ). Strange thing is that when engine dies, pumping throttle makes no difference but depressing the clutch to the floor and then bringing it back up again and then the throttle brings everything back to life ( just as well as it happened twice on the M3 ).
Also....if you take your foot off the accelerator, the rev counter goes to zero ( unless you are idling ), but works okay if using accelerator, and the speedo seems to think it is a wiper arm waving all over the place.
I have checked the battery and connections, checked fuel lines, changed filter but am at a loss what could be the fault, so would really appreciate any help. Cheers!
