Technical  Electric wing mirror conversion on bravo sx?
Fiatrick
Hi all!
I was wondering if anyone ever tryied this. to swap out the manual wing mirrors for some electric mirrors?
If its possible, what do I need apart from the mirrors, electric switch? (Am able to get oem mirrors+switch)
Thanks in advance for possible help :)
If you have a car after 1998 its easy peasy :)
The plugs are in the door. The hardest part is taking off the door card.
You can use your own cups if you wish, 3xT15 screws in the metal base and 2 phillips screws holding the cup to the mirror. Swap them round and you can leave the mirror loose or tight.
The buttons are plug and play on cars after 1998
The mirrors are heated too, operated by the heated rear window.
Don't forget those mirrors use different sponges and covers in the mirror (although a regular sponge will do the job)
I've done this twice (y)
Hello, I have a question (a very stupid one) :
are all electric mirrors heated to?
A picture that shows differences between the two is greatly appreciated.
