D dtwelve Member Joined Aug 31, 2014 Messages 137 Points 68 Location Near doncaster Sep 28, 2014 #1 hi has anyone got ecu pin diagram for doing the cruise control on a bravo 1.9multijet just need where the numbers start etc on the ecu plug cheers dave
bradgibbs New member Joined Aug 9, 2013 Messages 188 Points 44 Sep 28, 2014 #2 dtwelve said: hi has anyone got ecu pin diagram for doing the cruise control on a bravo 1.9multijet just need where the numbers start etc on the ecu plug cheers dave Click to expand... If you look on the top ( and bottom i think) of the plug you can see the numbers for each row
OP OP D dtwelve Member Joined Aug 31, 2014 Messages 137 Points 68 Location Near doncaster Sep 28, 2014 #3 phew that make it easy lol just making sure before I take things apart
A aurick86 Established member Joined Sep 14, 2009 Messages 2,068 Points 461 Location Bucharest Sep 29, 2014 #4 Here is the ecu pin out for the 1.9 16v: View attachment 1.9 16v ecu pins.pdf
N neilshep Patron member Joined Aug 17, 2008 Messages 1,329 Points 246 Location Peterborough Sep 29, 2014 #5 dtwelve said: hi has anyone got ecu pin diagram for doing the cruise control on a bravo 1.9multijet just need where the numbers start etc on the ecu plug cheers dave Click to expand... Connections are diferent for the 8 valve 120hp and the 16 valve 150hp
