Technical EcoWorthy Lithium Battery
I’ve recently changed 2 130Ah Agm batteries (5 years old) for a EcoWorthy 100Ah lithium battery with Bluetooth, has anyone had any issues with these batteries with regards to syncing them to victron products?
My victron battery monitor never gives me the same reading as the Bluetooth monitor built into the battery, for example my battery has been charging all day from the solar panel, my victron says it’s at 100% and the battery state is open (it’s still sunny) but the eco worthy app says it’s only at 68% and not actually charging, I’ve also noticed the % drops and different rates too I’ve tried playing about on the victron app with the settings to no avail. The % also drops on the eco app if I’m using electrics while the vehicle is running and I have a victron 50amp dc to dc charger so this can’t be right surely? Does anyone have any advice on settings or where I’m going wrong?
Model
Ducato
Probably you still have the Victron system configured for a gel battery? You need to select a lithium (lifepo) profile in the app settings.
Sorry, probably should’ve mentioned that, I have changed it to LifePO and still no better
Did you restart the Victron system or let the battery discharge a bit after doing the change of settings?
Since changing the settings, I haven’t restarted the victron system, I’ll look into how I do that but I have let the battery discharge a bit, also I’ve fully charged it and synced to 100% SOC through the victron app when the eco app and victron both said it was at 100%
