General Ducato headlamp adjustment
nowbus
2005 2.3JTD DUCATO MINIBUS
Hi, the dash adjuster knob is turned to zero but my headlights still seem to be aimed too high as I get oncoming drivers occasionally flashing me (and I could not possibly know all of them!). Can anybody tell me which are the under bonnet adjusters? Are they the 8mm. white nylon bolts/screws? Which one adjusts what plane and which way do you turn them?
Many thanks in advance, Nowbus(Howard).
Re: Ducato 2005 headlamp adjustment
When you are standing in front of the nearside headlight, there are two 8mm nylon/metal adjusting screws. The one on the left adjusts the up/down movement and the one on the right (nearest the radiator) adjusts the left/right movement. Screw in the left hand one to move the beam down (screw out to move the beam up). Screw in the right hand one top move the beam outwards (to the left when driving) and screw out to move the beam inwards (to the right when driving). The offside headlamp is a mirror image with the right hand screw for the up/down movement and the right hand screw for the left/right movement.
Hope this helps
