Technical  Ducato engine/box swap?
SomersetSteve
Does anyone know if a 2.2 hdi engine and box from an 02 plate van is a straight swap for a 1.9 td in a Y reg?
No! You'd need to swap almost everything in frontend loom, ecu, instruments, lift pump, immobiliser, pedals, linkages and thats assuming the chassis are the same weight. It would be easier to put in a vag tdi :D
