Technical Ducato based Motor home Jacking Points
davethespark99
I have a 2017 Rimor motorhome based on a 2.3 Ducato , I cant figure out where the safe Jacking places are . The hand book is no help as it only has a tiny blurred photo. Any clues folks
The jacking points on ducato are rectangle in shape with a hole in the middle for the standard fiat jack to slot in ,don’t no your design and layout but Iv seen some motorhome conversions cut into them for the gas locker to fit ,,1 on front under b pillar each side 1 on rear both sides in front of rear wheels look for rectangle areas that are lower that the chassis and they have a hole in the middle
Could be on alko chassis too in which case rear will not be fiat.
Good point corcai on them I jack up where shocker bolts onto bracket for shocker mounting just in front rear wheel but you can’t use standard fiat jack
Thanks for this information, whineO; safety first.
