rednwhitevan
- Joined
- Mar 24, 2017
- Messages
- 29
- Points
- 58
Hello, I have a vibration in steering wheel that started only at motorway speeds, now it is bad in right hand corners when weight is on left side.
I am pretty sure Its a driveshaft as boots have been split both sides for sometime although there is no clicking at full lock. It also goes away in left hand corners even when I accelerate. I hope it is not a wheel bearing do these fail on this model? The vibration is like an electric sander on steering wheel kind of.
Anyway, one question I am asking is are the driveshafts the same on different models? I have the high roof Van and I am pretty sure it takes heavier suspension than the other low roof versions. I also need new Struts.
Can anyone give me the original part number for my left and right driveshafts?
I need to get this right as it will take some time and expense sending these parts from Europe.
Also, if you can recommend where to buy these parts aftermarket that can freight to Australia that would be great thank you.
also can wheel bearings be done on the road or do they need pressed out?
I am just considering doing a complete overhaul of the front end whilst I have it stripped.. Struts, driveshafts, wheel bearings and brakes..
