Hi everyone
Due to the information found on this site (ducato elearn and wiring diagrams) I managed to repair the fault with my lights which was.
Every now and then the dipped headlights and main beams stopped working and then sometimes they would just switch off while driving.
I have found out that on these 2002 -l 2006 Citroen relay, Peugeot boxer and Fiat Ducato vans that an earth is supplied from the indicator/lights switch to an electronic module incorporated into the back of the bank of switches located below the radio i.e.. hazard lights, fog light and rear heater switches. It in turn should supply a earth connection to relay T02 located in the relay/fuse box under the bonnet. The electronic module was faulty in my case. This module also switches earths for the main beam lamps and the rear fog lights. Hope this helps someone.
