Here are a few of the "Important Notes" from the handbook:
- During prolonged halts with the engine running it is advisable to keep the gearbox in N
- To safeguard clutch efficiency do not use the accelerator to keep the car still
- If in R, first gear is to be engaged or vice versa only when car is stopped completely with the brake pedal pressed
- When needed with the engine off you can change gear with the key on MAR and the brake pedal depressed. In this case the instructions required to change the gear letting at least 5 seconds pass between one gear shift and the other in order to preserve proper operation of the hydraulic system.
- Opening the driver's door will make the system activate the hydraulic section in order to prepare it for the next engine starting
Buzzer indications - With the car stationary, the engine running and gear 1, 2 or R engaged, the system activated the buzzer and automatically shifts to N when - no action is made on the accelerator and or brake pedals for at least 3 minutes, the brake is pressed for over 10 minutes, the driver door is open and the accelerator and brake are not touched for 1.5 sec, and when a gear box failure has been detected.
Do not rest your hand on the gear lever!!
Here is a list of the Warning Lights and Messages ( let me know if you need more info )
Dualogic Transmission Failure, Reduce Gears, Manual Mode Not Available, Automatic Mode Not Available, Clutch Overtemperature, Push Brake Pedal- Delayed Startup, Gear Not Available, Operation Not Allowed, Push Brake Pedal - Repeat Operation , Set to Neutral
( In all cases it says that if the message stays on to contact Fiat Dealership)
