Hi Alex, Thanks for all the info. Only up to 40,000 & 3 years but I was a bit worried about the cost of a new transmission. I'll save your post. Bought the car for my wife to drive but love getting my hands on as often as I can.
Thanks again.
Cheers, Mick
No worries. Bear in mind that, unlike a conventional automatic, a ‘new transmission’ would be in two halves; the ‘manual gearbox’ part, and the ‘actuator’ (often called the ‘robot’) part, which is attached to the outside of the gearbox. You’ve probably seen the cost of a replacement actuator - it’s an all-in-one unit with the pump, pressure accumulator (sphere), reservoir, electrovalves, and hydraulic cylinders, designed to be exchanged as a complete module to repair any Dualogic faults. It even comes pre-filled with fluid, ready to simply bolt into place and calibrate.
This ‘modulisation’ was in answer to problems with workshops not knowing how to diagnose and repair the earlier Selespeed systems satisfactorily, and the long discussion thread running on this forum basically proves that intermittent faults can be frustrating and expensive (in workshop time) to try and solve without replacing the entire actuator.
These days at somewhere between $2000 and $3000, the actuator is relatively good value for what it is; try getting a conventional automatic repaired for that money
nevertheless I expect it will be possible to repair the seals, pump, accumulator etc. as an alternative strategy, when the cars are old and worth less than the cost of the complete module. It just hasn’t been practical yet, as it’s all been trial-and-error at the owner’s inconvenience.
Our 2008 500 has just rolled over 120,000km and is still on the original actuator, no faults. I expect our clutch assembly will need replacing some time before 150,000, but we’ll see. It’s a standard clutch, just like you would find with any other manual gearbox.
Anyway I wish you and your wife many kilometres of happy, economical, and reliable driving - as we’ve had
-Alex
