Went to the supermarket earlier and I couldn't get my GP drivers door open. I had to lower the window down and open using the outside lock.
I removed the door panel and can confirm that the cable is still attached to the back of the handle and the fault seems to be something not engaging inside the lock itself.
Can someone advise if these mechanisms are repairable or are they just replaced if the fail. Whatever has failed seems to be just under the catch that engages with the striker on body of the car.
