DPF Problem - Is this a feasible solution?
I will get a KKL inteface and attempt a forced Regeneration myself. Will be interesting to see if I can clear the value/reduce the value of the DPF unit obstruction.
You WILL clear it , only for it to return later. You need to remove ALL x ref to the DPF algorithms within the ECU s/w or reset all values that the car would never reach in a hundred years [ this is NOT the job for a begineer!?!@] even remappers have got it wrong :cry:
