Squirreldirector
Doblo :devil:2004 model (LHD) 1.6 16v
Fault Codes:
P1220 - Throttle Control Valve (throttle body replaced ) .. x 2
P0101 - Mas Airflow Volume
P0105 MAP Sensor... (replaced & checked) ...twice
P0110 Intake Temp Sensor (is part of Map Sensor)
If you start it up from cold and rest all the faults it idles and runs fine for 2 mins or so. Then Mil comes on and you have know throttle.
If you disconnect the MAP sensor it will rev perfectly but the idle goes up and down from 900-200 (like its searching) Fiat said they don't know (I am here in on an island in Greece so thats not really a shocker)
Have replaced (swapped) every component about to torch the f*****:devil:
Fault Codes:
