Technical doblo 1.6 cdti EGR valve
steelcitydj
sheffield
hiya, got a doblo with the 1.6 diesel enging in. the EGR valve needs replacing, the egr valve is located at the back right of the engine and as far as im aware is secured by two torx srews, ( top and bottom ) ive removed bothe screws but the valve is still solid to the engine.
please, please can someone give me some hints or tips on how to remove this. access is very limited as its at the rear of the engine . i need this for work so desperate to sort it.
thanks guys.
Hi there
I have a Doblo 2012 same engine. Years ago I removed egr valve to clean it. Move it up down left right or use a screwdriver to separate from body.
