do these exist ? (ice question)
B
Bahney
at the moment i have like a screw clamp to connect my power cable/ground cable into my amp but the cables are thick and they never go in the whole way so i was after something like this :-
ok when you have stopped laughfing at my **** poor ms paint skills i will explain what the pic is :) i want to clamp my thick power cable with like a larger metal hoop leading into a smaller metal hoop which i can screw into my amp, firstly do these exist ? and more importantly what are they called and where can i get one from ?
thanks in advance
ps i have searched the web but it is hard when you don't know what something ic called :)
Re: Re: do these exist ? (ice question)
I think what you have is the bottom part of the pic...and you want to change it to the top of the pic???
...also excuse the paint program...
Daz
Re: Re: Re: do these exist ? (ice question)
daz mate that is perfect, do they exist ? or something similar to that ?
Re: Re: Re: Re: do these exist ? (ice question)
Its called a ring crimp or ring terminal. What size do you need? (wire size and bolt hole size)
Re: Re: Re: Re: Re: do these exist ? (ice question)
my wire is quite thick i would say about 10mm diameter and the hole i want to make it into needs to be about 8mm diameter
Re: Re: Re: Re: Re: Re: do these exist ? (ice question)
Thats quite thick! 4 guage?
Re: Re: Re: Re: Re: Re: Re: do these exist ? (ice question)
yeah i think so, i threw away the power kit so to be honest i am not 100% sure but 4 gague sounds familiar
Re: Re: Re: Re: Re: Re: Re: Re: do these exist ? (ice question)
The core is about 6mm diameter? (10mm overall with the insulation?)
Re: Re: Re: Re: Re: Re: Re: Re: Re: do these exist ? (ice question)
yeah that sounds about right, obvioustly i cant measure exactly but i can take more detailed measurements tomorow morning, but i had a good look today and i am going by memory.
but yeah tom that sounds right
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: do these exist ? (ice question)
Yup, 4 guage or 20mm^2.
Ideally you need a big old crimp tool for these but you can just about get away with pliers, a hammer and a vice. :)
What you need is farnell part 269-001 (www.farnell.co.uk) £3 for 10 BUT there is a minium order of £10. You could try local car electrical places.
I don't have any that size.
just been looking on a few websites, this looks like what i am after, says it does it in a 4 gague as well, but would somewhere like halfords stock something like this ? or would i be better off mail order ?
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: do these exist ? (ice question)
Helf do them I think but might only be the ripspeed ones. Any good ice shop should too.
You can get a "crimp lug" from any elec wholesaler
Just tell them the size of cable and the hole size you want they should have thousands of these on there shelves.
Rab.:)
"If at first you don't succeed lower your standards".
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: do these exist ? (ice question)
just measured my power cable and it is 7mm and that includes insulation
so what gague does this make it ? still 4 gague ?
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: do these exist ? (ice question)
Yeah, 4. Its not small enough to be 8 guage.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: do these exist ? (ice question)
nice1 cheers tom, i just called hellfords and they dont have any in stock till friday, any ideas where i can get one online ?
1
644
Dark Lurker
B
2
519
BRUNO
B
M
284
M
M
2
721
M
