Technical de cat pipe?
Bedford
hi,just posted this in the tipo section but i think one of you may be able to help me aswell. i need to know if a de cat pipe for a coupe will fit on my tipo as supersprint don't list a de cat for a tipo....help!
cheers...darren :)
custard boy said:
could always go to somewhere like powerflow/longlife and get them to make a de-cat pipe
yeah suppose,just thought it might be easier to buy one from carnoisseur or something as the car is off the road now,cheers for your help again (y)
I wouldn't have thought they were the same to be honest. Tipo probably a different body length to the Coupe so probably different exhaust systems.
H
H
the de cat could still be the same though and the de cat back could just be different,it looks very much like it would fit from the picture in the catalogue but i just want to be sure because if i order it in then i won't be able to return it (n)
Would you like me to measure the cat off a Coupe 20V Turbo for you? I have one in my kitchen! That should give you a clue.
H
The dimensions of the cat are (approximately):
Total length: 765mm (of which 75mm slides within the exhaust pipe)
Bore at exhaust end: internal: 52mm, external: 54mm
Internal bore at the flange (internal) end: 50mm
Minimum wall thickness at the flange end: 15mm
Mounting bolt pitch diameter at the flange end: 88mm
Mounting bolt hole diameter at the flange end: 10mm
Hope that helps,
H
Hope that helps,
H
cheers,much appreciated. i will let you know how i got on.
No it's behind the door. The fridge would be a weird place to keep a cat, don't you think? :confused:
I threw some cheese away at the weekend. It wasn't even bought by me, but by a regular visitor of mine. :rolleyes:
H
