General  Dashboard light explanation
allan16
Hello,
I have a 2005 Fiat Palio ELX and when I got in to the the car to go to work it all worked fine but there is a light coming up on the daskboard that I don't know what it means.
Its in yellow color, in circle shape, kinda looks like a light bulb but not exactly. I would appreciate some help.
If someone knows what I am talking about can you please advise me on why is this light coming up and what do I need to do? or if anyone has a document that explains this it would be really appreciated.
Thanks!
Were exactly U see the light, right side of the dashboard, left side or center.
Provide with snap shot so that it will be easy to let you know the exact problem.(y)
Left side of the dashboard. I'll have to take a picture and attach it here but not till tomorrow :S
It is nothing but low fuel warning buld, check if your fuel meter is wokring fine or if there is any issue with the wiring.:idea:
I have a 2nd generation Palio, and when I turn the key (without starting the engine), some lights appear, including this yellow one, the fuel light. Then they all turn off, seconds later.
That's normal, the system is checking eletronic system stuff, and if everything is fine, the lights disappear.
If the yellow light does not disappear, then you are low on fuel or have a problem with the fuel meter.
